Old 05-23-2008, 09:09 AM
bkilby's Avatar
bkilby bkilby is offline
Default Older parachutes?
Would you wear an older parachute (+ 20 years old)? Or is this a case of no way would I buy/wear a 20 year old parachute? Assuming it has been stored properly and inspected and repacked on schedule. Just curious what others think.
Old 05-23-2008, 09:27 AM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Yes, I would and yes I do. Parachutes are like airplanes, if they are inspected and repaired by a qualified person they should be good regardless of age.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 05-23-2008, 09:41 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Have it inspected...
If I knew that it was stored properly (wasn't exposed to UV or moisture), knew the owner, and had a reserve packing card that showed the repack cycle history, maintenance, etc, I might consider using it. I would definitely also have an experienced rigger look at the canopy, harness, and container as a pre-buy inspection, and also determine if there were any other issues. Especially a rigger that has been around +20 years... I know for a fact that back in the '80's there were some canopies that were treated with a fire retardant (by mistake) that was also used on tent fabric consequently weakening the materials. Those canopies should have been grounded and had the lines cut off them. Who know where those canopies really ended up though...
Just my $.02
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 05-23-2008, 09:52 AM
n468ac's Avatar
n468ac n468ac is offline
http://www.silverparachutes.com/
Allen has alot of good information on his site. "Is Your Life Worth $80.00 A Year?" This is one reason i got a new chute from him. I don't want to jump only to see the chute not work ... my life is worth the full price of the chute.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 05-23-2008, 03:35 PM
1:1 Scale 1:1 Scale is offline
Joe, I have a SAC in a box in my shop right now, I've even used it before!
The biggest issue with older parachute equipment is that there's no non-destructive way to test the materials for UV degredation, so that's why some companies and riggers put a time limit on parachute equipment. Simply handling the parachute fabric can be harmful due to the oils and salt in perspiration.
Kelly
RV-7 empennage done, wings done, fuselage to QB stage.
1973 Maule M4-220C flying
Old 05-23-2008, 10:07 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Talking Its not age its condition and that applies to pilots to!
It is not age its condition.
It is recommended you never leave your parachute in your plane.
You should store it as much as possible in temp, humidity controlled environment, like in your house.
You should also have a container for it. Old luggage makes a fine case to store it in; I especially like an old hard case style luggage.
Ditto on: http://www.silverparachutes.com/ Allen's site. I have been to a few of his lectures. I have posted many links from his site. Well worth a read through. He's a real jumper that caters to emergency parachute crowd. For a round chute there is no need to ever jump, to use it in an emergency, BUT!!! you better do some reading, thinking and dry runs on the ground. Read my previous post on the subject.
My "silk" is military surplus 28 foot C-9 in paraphernalia softie shell/harness. The canopy is in perfect condition after many years. I was told there was no life limit, and military canopies have higher opening speed limits.
Why would there be any UV damage?
Are you storing it in a sealed luggage container in your house? If you leave it laying around in the sun, dirt, heat and humidity, than it might not last very long.
Of course I never have "used it" except to get packed on occasion.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 05-24-2008, 02:17 PM
mbell mbell is offline
I have bought several chutes from Allen Silver and respect his opinion. As I recall from our last conversation any chute over 20 years old is only good as a car (or plane) cover.
Old 05-26-2008, 12:08 PM
I tend to agree with you, George, but the harness will get UV exposure every time it is worn, and with many colors of webbing, it is hard to tell how much exposure it has had, and even then, some dye lots hold color better than others. There are ongoing debates in the parachute industry about life limits and liability exposure. It seems that "personnal experience and judgement" won't be much of a defense if a parachute rigger is drawn into court if one of his customers dies.
Personally, I would wear a harness/container/parachute that was over 20 years old if it met my needs. However, I would be the one packing it, so there would be no one to sue if it failed To me, it's a game of odds- the odds of needing to leave you plane in flight are pretty low, as are the odds of the parachute failing after you get out of the plane. You're surely safer wearing a 1930's parachute than you are wearing nothing at all
Kelly
Old 01-12-2010, 05:19 PM
rmarshall234 rmarshall234 is offline
If it's made from modern materials (nylon) and has a current repack by a qualified rigger I'd say absolutely. An inspection and simple pull-test would determine it's integrity.
(30 years of jump experience and senior parachute rigger)
Old 01-12-2010, 05:45 PM
skyfrog's Avatar
skyfrog skyfrog is offline
Default No Thanks
I've heard Allen speak at Sun-N-Fun and agree that the purchase of a new, or modern chute is a better choice.
First off, I would say that a properly packed and stored chute will probably work fine. But think about that... *probably*. Materials break down over time, and while a rigger will check the material, a weak area may go undetected. I've jumped old sport chutes and never had a problem, but then I had a reserve chute.
Secondly, the technology of the materials have advanced, making for a lighter and smaller packing chute. I'm amazed at the size of the new chutes.
Finally, when purchasing new, you can get one sized to your weight and even get a square over a round. That's what I did...
John Edwards
jedwards@digital.net
VAF #1089
