Old 05-22-2008, 06:02 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default vans lights -which is which
On the Vans wingtip landing light combo, which are the landing (inner or outer) and which are the taxi?
Old 05-24-2008, 08:24 PM
RatMan RatMan is offline
I don't remember the instructions stating which is taxi and landing but the outboard lights can be aimed inward to cover more of the area directly in front of the aircraft so I used those as taxi. The inboard are limited to vertical aiming because the wingtip cutouts block more of the horizontal light.
Of course you can use all of them for landing but in a taildragger, once the tail drops one set will be aiming more upward than the other. On a nose dragger not such an issue.
John Ratliff
N898R
RV-8
Saucier MS
