Old 05-21-2008, 10:40 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Cool Lube rod end bearing on intial install
I am working with the aileron push rods and wondered if they should be greased or lubed during the initial install. They seem to some with some type of lubricant. I did read a thread about folks using various lubricants on the conditional inspections, I just wondered if I should do something on the initial install. Hopefully it will be some spray product because the rods are installed at this point. I don't remember reading anything from the plans on the subject.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 05-22-2008, 05:31 AM
Geico266's Avatar
Geico266 Geico266 is offline
I use LPS2 on the rod bearing ends.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
