05-21-2008, 05:36 PM
Manual Trim Knob
Looking at some 6A panels, the vertical piece between the fuel selector bracket and the panel has been omitted and an extension mounted below the panel to mounted the mixture, throttle and carb heat (and prop control if used) side-by-side is installed. This makes it much easier I suppose to get under the panel when you need to since the vertical member essentially gives you half the room. Has anyone mounted their cable controls in this manner that uses a manual elevator trim? If so, where did you put the elevator trim knob so that the cable is not a cockpit obstruction?  Pictures would definitely help if you had them.
thanks loads!
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build  )
N621TR In unrestricted operation
05-21-2008, 06:38 PM
This is how I dealt with it. It has worked very well for well over 400 hours of flight time. You may notice the carb heat knob at the right of the sub panel. This proved to be very bothersome to my passenger on a long haul. I cut off the right end of the sub panel and moved the carb heat control up into the panel. I also added a CHT gauge and an outside air temp gauge to the right side panel and the Altrak switch to the left part of the panel, replaced the turn coordinator with a Pictorial Pilot (autopilot), added associated circuit breakers and switches and removed the gyro instruments for overhaul with no access problems. As you can see my RV-6A is a slider.
Bob Axsom
Reason: typo
05-21-2008, 07:12 PM
I put my manual trim control about the same location as Bob, but attached to the panel below the quadrant.
Much better when flying in formation and the knob does not interfere with my leg. It's easy to remove with two screws and lay aside when crawling under the panel.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
05-22-2008, 09:38 AM
Vernon,
Does this mean you have two subpanels attached to the panel, one for the quadrant and a second one attached below the quadrant panel for the trim? I then assume the second one attaches to the first quadrant, which attaches to the panel. This sounds like an arrangement which might fit my desires.
Tim Ribble
Virginia Beach
05-22-2008, 10:24 AM
It's not a great pic but you get the idea. The cable goes straight forward, runs down along the firewall to the floor, and along the florr under the carpet back through the spar/ bulkhead. It is secured in place by about half a dozen adel clamps along the firewall and floor stiffeners.
The trick is to get a longer cable. IIRC the cable was 40 inches longer than the standard, but you should mock it up with some romex or similar first and measure.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
05-22-2008, 10:49 AM
RV7 finish kit?
Depending on your finish kit date, you may have the 7 kit. This would be the firewall mounted battery, etc...
If you add on the FI portion of the kit, Van's can help you, it will come with parts for the FI pump and all of the appropriate parts to dress up the fuel selector and Manual Trim. It is very clean and neat requiring only slight modification where it attaches to the spar as that is different on the 6 vs the 7.
Even if you dont need the FI, the parts make it easy and clean and the tunnel is a great way to route wires aft and through the spar.
I will send you pics tonight.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
05-22-2008, 11:01 AM
Trim cable location
I mounted mine facing aft. I shortened the manual flap handle and placed it (the trim cable) so the knob faces forward from between the seat cushions. The knob is completely accessible and logical in usage. Since I put my fuel selector on the left side, there is no interference. A little metal work and you can make a nice cover which hides all but the knob. I wish I knew how to do pictures.
05-22-2008, 11:11 AM
Just add a small "ear" to the front of the fuel selector bracket angled up about 45*. My -6 and many more have done this. Been working great for over 15 years.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
