Originally Posted by Jeff R
When you say hour meter, do you mean a Hobbs, or do you mean the hour meter that is on the tach guage?
If you mean a Hobbs, I am curious as to why. I thought all maintenance requirements were based on tach time.
Not really.. to be precise the
FAA bases time for maintenance on flight hours - the FAA calls it "Time-In-Service". There are a few AC docs that give the details.
Bottom of page 3 of this document, as an example...
Long, ugly FAA link
In practise, this is difficult to do and the tach time is used as an approximation. The mechanical tach time gives hours of engine operation based on a specific cruise rpm.... run at 1/2 the cruise rpm, and time takes twice as long to record.....
Some digital tachs just count time above a rpm threshold (800 rpm on my Horizon)
The true way to record time would be a timer based on an airspeed threshold, as in some of the newer panel mounted GPS units. I'm not sure how the different EFIS guys do it....
Of course, all of this is not critical in our homebuilts, since we do not need maintenance hours for AD compliance.
gil A
PS.... this is for maintenance, your pilot logged hours are different...
