Old 05-20-2008, 12:04 AM
vhbill vhbill is offline
Default Earth Terminal Blocks
Can anyone let me know where I can get small earth terminal blocks for 1/4" fast on connectors? B&C has large ones, but I would like a smaller one, with about 8 terminals. Thanks, Bill
Old 05-20-2008, 02:13 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default B&C does sell 1/4"
Earth, Ground block? 1/4" or 7/64"?
B&C sells the 1/4" tab ground blocks, for the 1/4 fast on connectors. I wouldn't call them large but standard or normal.
There are smaller 7/64" fast-on tabs. Not sure why you would want that for a grounding block?
Try Digikey, Mouser, Newark. They have terminal blocks where you can screw on fast-on tabs. Not sure what sizes they have, but know they at least have 1/4" which you don't want? You can also take these standard tabs and rivet them onto copper. Most also solder them on as well.
Personally I'd just go with the B&C deal and buy the appropreate 1/4" fast-ons. The 7/64" is too small for aircraft in my opinion. Good Look
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 05-20-2008, 03:34 AM
Harold Lanfear Harold Lanfear is offline
Default Steinair has them
Assuming you are looking for fewer tabs; Steinair has tabs with 10 tab strips for $1 each. They are tabs only, so you you'll have to solder it to a brass backer. Strangely enough, they are listed under "Accessories"
Hope this helps.
Harold
Kitfox sold 2010; RV-8 85% and moving at the speed of a used Edsel
Old 05-20-2008, 11:41 PM
Thanks for your advice gents. fyi, I'm putting an fast-on earth terminal block in each wing tip to earth the wing lights etc. so need a small one that has about 8 connections max. I'll check out the leads you have taken the time to give to me. Rgds, Bill
Old 05-21-2008, 12:37 AM
Rivethead Rivethead is offline
Default Rolled my own
I built these ground busses out of terminal blocks I happened upon at Fry Electronics (same ones B&C sells) and some of the copper strip provided in the Van's firewall forward kit. They are connected through the firewall via a 5/16" brass bolt.
Fast on tabs, if I use them, will come from Steinair. http://www.steinair.com/strips.htm #SA-308
Old 05-21-2008, 10:04 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
One large B and C multi tab ground block, plus one hack saw, equals two small ground blocks, and custom sized to boot
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-21-2008, 10:44 AM
fl-mike's Avatar
fl-mike fl-mike is offline
If you buy a fuse block with the ground tabs option, you can use as is or cut the ground block section off and use elsewhere.
http://order.waytekwire.com
see product #46061 or similar
http://order.waytekwire.com/IMAGES/M...og/220_073.PDF
Mike W
Venice, FL
N164WM
