Originally Posted by Stevejohnson7@gmail.com
Scott, You have me confused now. You wrote: "If I were to do it again I would probably just do the flush latches that most people use". Can you please explain to me the reasons why you would do the above?.
I spent alot of time on this latch and it is a single point latch. With less work I could have had a system that has a two point latch system, less work and most likely a stronger system.
I have multiple failure points (one latch, the wire that is crimped in the latch, ect..) and even though it is cooler to have a clean looking oil door, when you are at some grass strip in the middle of no where it is nice to have stuff that is simple and has a very low chance of failure.
I have had zero issues with this system but just something I would different now.
http://www.rvproject.com/20031101.html
Someday I may switch to a system like the one above.
But everyone should do what they want. Most of us will probably only build one plane in our lives and might as well make it just as you dream.
