05-18-2008, 06:32 PM
HELP - mag wires not right length!!!!
I spent the last hour reviewing mag wiring when it seemed the wires were not correctly cut to length (it came that way) My engine manual wiring is the same as the other threads I have read.
Mags from the back:
Left
42
13
Right
31
24
Here is the problem:
Left mag - the longest wire on it is on #4 and should be on #1. The shortest wire is on #2 and should be on #4.
Right mag - Longest wire on # 3 and should be on #2. The shortest wire is on #1 should be on on #3.
Lengths are perfect for the wrong cylinders!!!! If I could rotate each cap a quarter of a turn CCW, it would fix it. Problem I see is there are 3 screws and won't happen.
I thought about flipping the mags but it still won't do it. What's the best fix?
Webb
RV7A - N32WW
05-18-2008, 06:54 PM
Mags from the back:
Left
42
13
Right
31
24
Webb
RV7A - N32WW
There seem to be a few of us working with ignition harnesses this weekend. What make and model of mag are you using? Mine isn't like the manual.
Check out these threads
http://www.vansairforce.com/communit...ad.php?t=17320
http://www.vansairforce.com/communit...ad.php?t=30138
Jim Sharkey
RV6 - Wiring
05-18-2008, 07:30 PM
It's important to match the cylinder numbers, but it's NOT important whether it's top vs. bottom plug... that thing (as shown on the drawing) is a convention, not a requirement. It's absolutely irrelevant whether left mag fires top plug on #1 or bottom plug on #1.. and so forth.
So, if you can "make it work" then you can do so.. ignore those drawings.. just match numbers.
Radomir
RV-7A sold
05-18-2008, 07:48 PM
Go figure
Jim,
I just went out to the shop with a flashlight and checked the spark plug nuts. The are marked and the lengths are proper for the markings but how they are connected to the mags doesn't agree with my Superior manual or the Lycoming diagrams on the threads you provided. I checked those threads earlier and they are the same ones I looked at before making this post. When I said if I could turn them each a quarter turn, they would match my manual and the other manuals in the threads.
Book for left mag and threads
4 2
1 3
My left wiring
1 4
3 2
Book for right mag and threads
3 1
2 4
My right wiring
2 3
4 1
I kid you not, if I could turn each a quarter of a turn, they would be perfect. My gut is the spark plug leads were not wired correctly. I'm calling Eagle Engines who built the engine unless there is an easy way to pull the caps, and rewire. My gut also tells me this shouldn't be that hard since plug wires do go bad and have to be replaced. However, not having done that before - its just a guess.
So I guess my request for help is how big a deal is it to rewire the spark plug leads??????
Webb
05-18-2008, 07:55 PM
The wiring convention is there for a reason....
Well not quite....
The "convention" is in place to enable the correct application of spark plug rotation. The pulses are both negative and positive, and the recommended sequence of spark plug rotation, along with the correct convention of wiring, evens out and extends spark plug life.
Of course, if you don't bother to rotate your spark plugs, then ignore the wiring convention.... YMMV
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-18-2008, 08:23 PM
Mystery solved
After reading Jim's post, I realized that we both had the same issue. Too much of a coincidence.
I went out to the shop and got the flashlight and mirror out. The Unison slick mag cap has cylinder #1 stamped top right (left mag) instead of bottom right. Same for right mag. Darn thing is rotated 90 degrees from the drawing.
Bet your bottom dollar I'll make the corrrection in my manual although I doubt I'll forget this one.
This makes the wires correct and correct length for the cylinders.
Mystery solved, cased closed. I don't recall who posted the info on Jim's post about the cyclinder # stamp on the plastic cap - but thank you.
Webb
05-19-2008, 04:38 AM
Webb
The beauty of VAF - and 5,000+ RVs to get experience from
Lots of people at the same stage
Jim Sharkey
05-19-2008, 06:23 AM
Time Lost
Jim Sharkey
I'm glad I spent the time verifying - I just hated losing 2 hours of time in which I would have had the wires routed and secured.
Thanks for your help - hope I helped you.
Webb
05-19-2008, 02:01 PM
But in a long run, does this really matter? I read about rotating plugs earlier but can't remember all details (added it to the subscribed threads for future use). I assume in a long run, the ninth time the plug should be at the place where it started it's rotation and while that it has been in every spark plug hole by then. If so, it should be as much in lower and upper holes as well as get same amount of negative and positive pulses.
I might have said that shorter, but hopefully you got what I meant.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
05-19-2008, 04:05 PM
Rotate is really a swap....
Pirkka,
Your statement would be true if it was a true rotation, with a specific plug passing along all of the holes.
...but it's not a true rotation... the Continental 6 cyl. pattern can be seen here...
http://www.sacskyranch.com/spark.htm
It's more like a swap between pairs of holes. If this pattern is followed, then a single plug might always get positive (or negative) pulses for it's whole life - if the wiring convention is not followed.
gil A
Gil Alexander
