Old 08-27-2005, 03:32 PM
mtclay mtclay is offline
Default Tailwheel Dolly (Towbar)
I remember viewing the URL of a company that makes dolly-type tailwheel towbars, but I can't seem to locate it again.
Does anyone know what I'm talking about and the web address?
Mike
Mike Clay
Orlando, FL
RV-8A N81PD
Old 08-27-2005, 03:54 PM
Default I think I found it
Sorry folks. I think I found what I was talking about on Aircraft Spruce (that is not where I originally found it).
They have two models for sale: 1) The "Tail Dragger Dragger @ $139.95; and, 2) the "Rolling Towbar for Taildraggers" @ $235.95.
Does anyone have any experience or recommendations on either of these dollys?
Thanks again,
Mike
Mike Clay
Orlando, FL
RV-8A N81PD
Old 08-27-2005, 04:55 PM
No experience with the expensive versions, but a Cessna nosewheel tow bar does very well at grabbing the nut an bolt that serve as the axle on an RV's tailwheel. Aircraft Spruce sells a folding one for ~$40, and it is great for maneuvering the airplane on the ramp.
Old 08-28-2005, 05:52 PM
CraigH@KRPH CraigH@KRPH is offline
I think this is what you're looking for: www.dragger.com
I've used on on my Citabria, C140 and Tcraft. Best piece of equipment in my hangar!
Craig Helm VAF #585
Graham, TX (KRPH)
RV-4 (sold)
RV-6A (sold)
Old 08-28-2005, 07:01 PM
N941WR's Avatar
N941WR N941WR is offline
Default I'm not sure this would work on an RV
One of the small grass fields around here has an old lawn tractor with a bracket/tray welded on the front. They pickup the TW, put it in the tray and pull / push it with the 10 hp lawn tractor. The only problem with the RV?s is there is no lift handle in the tail section, so I?m not sure that would do the trick or not.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-28-2005, 07:59 PM
The tail spring works just fine as a pickup handle. It can be fairly heavy, depending on how the airplane is loaded.
Another option would be a slightly customized set of hand trucks. You can buy standard hand trucks at places like Harbor Freight for $30 - $40. If you or a buddy has a welder, you could customize them to work very well for picking up the tail of an RV for on-field movement.
Old 08-29-2005, 10:54 AM
John_RV4 John_RV4 is offline
Default Up Hill ??
Can anybody comment on the ability of the taildragger dragger to help with an uphill climb ? I have to pull my RV4 uphill (slightly) into the hangar.
Right now, I just pickup the tailspring and start walking backwards. This procedure is getting old. Or maybe my back is getting old :-).
Regardless, I'd like to find a better way.
John
Old 08-29-2005, 11:26 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
John
I guy at my old airport used an electric winch attached to the back of his hanger to pull his plane in. Worked great the time or two I saw it done.
Steve
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 08-29-2005, 11:31 AM
N941WR's Avatar
Default A better way
John
John,
An old friend of mine installed an electric winch in the back of his hanger to pull his Stearman in AND OUT. To pull it out he would put a bar with a pulley on one end and slide it in a pipe he had buried in the ground out in front of his hanger. He would then run a cable under his plane through the pulley and back to the wench.
The winch had a control box on the end of a long cable so he could stand next to his plane and guide it was being pulled into his hanger.
(Looks like Steve and I were posting at the same time with the same idea.)
Bill R.
SC86 - Easley, SC
Old 08-31-2005, 08:20 AM
ldagley2k ldagley2k is offline
Mike,
Wag Aero has one that was designed by an employee. I've been using it for my RV4 and it works well with some modification (non-skid material on the wheel bars). They have a web site where you can get address and phone numbers.
Larry D
