Maybe there is someone out there that has the service instructions they can share with you. Last time I messed with a carb was in A&P school in 1970.
Opening up the jets is a big no no for a lean engine. Either it's the wrong carb for your engine or something else is going wrong In other words, float levels may change as carbs age, usually because the seat wears, jet sizes don't. If the float level is too low and you correct that, you may or may not be too rich. Based on the now modified shape of the jet, it may never work properly again. Not all jets are straight through holes. Some are stepped or tapered. Any particular jet is designed for a particular engine and should not be altered.
Another thing to consider is the mixture is changed by varying the air pressure on top of the fuel in the bowl. A malfunction that system could be causing it to call for a lean mixture while rich is selected. That's another symptom of wear.
Like I said, they seem simple, but are actually pretty complex. For a good read check out
http://www.kellyaerospace.com/articl...essory_AMT.pdf
Personally I get a good shop to repair it before putting it back on the engine.
Don
