Old 05-13-2008, 11:12 AM
szicree szicree is offline
Question How to de-floptube a tank?
I've now decided that my plane will never need a floptube and am leaning towards switching back to a fixed fuel pickup. I figure I'm supposed to open the tanks anyway for the safety wire thing, so I may as well do it. However, it's been so long since I built them I can't even remember what the differences are. Obviously I would relocate the fuel sender back to it's original location and close the hole in the rear baffle with a solid plate. I seem to remember some hinges, trap doors, and guides that should be easy to put right. As for the actual removal of the flop tube itself, what should I use to plug the hole in the nose of the inboard tank rib? Any other advice would be great.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 05-13-2008, 11:26 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Seems to me that the easiest thing to do is make a rigid fuel pick-up and mount it in the same position as the flop tube you remove. It would be a simple matter to make the new pick-up tube lay against the bottom of the tank all the way to low point corner. It will be longer and may have to add a small angle or bracket to keep it down (keep it from moving). Can't think of any reason you would need to relocate anything.
You could remove the tap door, but since it not really designed to be fuel tight it is not going to make any difference either way.
**Just saw the RV-4, so your tank may be (probably) is different, but then again .....
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 05-13-2008, 11:36 AM
ddurakovich ddurakovich is offline
I removed the brass weight and safety wired the flop tube in place, safetied a cap on the fitting in the rib, fabbed a new pick-up tube, and pretty much left the rest alone.
Some 85 hours later, some mild acro, and all is well. If I ever decide to do more aggressive acro and configure appropriately, it will still be there!
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
Old 05-13-2008, 12:44 PM
N941WR's Avatar
N941WR N941WR is offline
Default Why?
Why remove it? It should have no impact on your flying or fuel pickup.
I like the idea of safety wiring it in place so your engine will stop if you go negative.
And heck, if you ever want to do inverted stuff, just add the oil system and you are good to go.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-13-2008, 05:25 PM
rv8guy's Avatar
rv8guy rv8guy is offline
I took the flop tube out and bought a fitting to seal the AN fitting at the front.
I left the fuel sender in bay 2, and I added the fuel pick up in the access plate as standard.
This could be reversed very easiily, giving me or future owner flexibility.
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 05-13-2008, 05:38 PM
Geico266's Avatar
Geico266 Geico266 is offline
Bill, why would you want the engine to stop?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-13-2008, 07:26 PM
N941WR's Avatar
Larry,
With no inverted oil system it is desirable to fuel starve the engine rather than letting it continue to run w/o oil. Once you complete your negative G maneuver, the engine will probably restart on its own. If not, hit the button and if that doesn't work, time to practice your glider skills.
If the engine continues to run when pulling (pushing?) negative G's without an inverted oil system you will soon find yourself in a glider anyway, maybe even one that is on fire after the engine grenades.
Bill R.
SC86 - Easley, SC
Old 05-13-2008, 07:33 PM
I find this to be the most appealing plan. Thanks to all who've responded. For those who wondered why I'm bothering, it's mostly to eliminate one possible failure point, save a few ounces, and avoid the ridiculous challenge of plumbing around the forward tank mount.
Steve Zicree
