Don't really have pics, but I did it by making a tray to fit the bottom (with vertical orientation of the GPS) and held the top in place with a tab. The tab has a hole that the power connector comes through, perhaps 5/16". Tilt it slightly and start the power connector through the tab, rotate it to straight up and a spring catch holds it that way. Put the power wire on and screw it down. Works great and has for over 100 hours. It is sort of "L" shaped with the tab on the upper left and the tray on the bottom. Simple to make with aluminum and rivets.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
