Old 05-12-2008, 04:25 PM
ROBERT DAVIS ROBERT DAVIS is offline
Default Best way to get more HP out of a IO-320 B1A
Hi.
I want to get more Hp out of a IO-320 B1A. Can anyone here give me their idea's on the best way to do this.
davis@mind.net
Old 05-12-2008, 05:26 PM
Ted RV8 Ted RV8 is offline
Default Compression
You can get 160 horsepower with stock Lycoming pistons from the 160 horsepower engines. I believe the B1A has a rear facing injection servo, you didn't state what airframe this is in, but a forward facing servo can get a pressure boost from the forward facing inlet in the engine cowl. Would have to change the sump to achieve this
Tuned exhaust as in the Vetterman 4 into 2 or 4 into 1.
There are lots of other things to make horsepower in engines. These are the easiest with noticable results.
Ted
Old 05-12-2008, 09:22 PM
az_gila's Avatar
az_gila az_gila is offline
Smile 340 Stroker
Perhaps a really good application for the ECI 340 Stroker kit?
http://www.eci2fly.com/exp/retrofitkits/csh340.aspx
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
