Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 05-12-2008, 02:44 PM
vbpiper's Avatar
vbpiper vbpiper is offline
Default GPS III pilot to Dynon D10-A
Does anyone have a GPS III connected to a Dynon EFIS? I know that the data sentences output by the GPS do not match all of those listed as needed for the Dynon, but I wonder how well they will function together.
Any input would be much appreciated!
Thanks.
RV-7A Finish kit
Renewed 8-14
Old 05-15-2008, 08:37 PM
grenwis grenwis is offline
Default GPS III Pilot to D10A
That's the setup I'm using. Works great. I output from the GPS to three things - D10A, EMS-D120 and my autopilot. Everything works as long as you select NMEA output format in the GPS setup screen. I don't know of any problems with that configuration. My GPS calculates winds wrong on its E6B and that same error shows up on the Dynon, but I think that is because my Dynon needs a magcal. What error are you referring to?
RV6A Slider - 180HP - Catto 3 blade
http://rickgrenwis.tripod.com/rv6a
APRS - KA4HRD - Denver, CO
http://aprs.fi/?call=ka4hrd&mt=m&z=11&timerange=3600
Old 05-15-2008, 09:14 PM
vbpiper's Avatar
Default Thanks
Rick,
Thanks for the response. I did not mean to refer to any specific error. I was checking the documentation for the D10A and the Pilot, and most of the sentences match up, but some do not, so I just wanted to know if they "talked" to each other well enough to be functional. Sounds like I do not have to invest in a new GPS yet! (At least until I can sneak some pork past the "appropriations committee" and buy a 496 :>)
I think I will hook the GPS up to the 327 txp, too, to see if the transponder will switch to ALT automatically.
Thanks, again.
RV-7A Finish kit
Renewed 8-14
