05-12-2008, 08:11 AM
RV-7 / RV-8 wing difference
Can anyone tell me the differences between the RV-7 and RV-8 wing? Seems like they might be close to identical....
05-12-2008, 08:50 AM
Not sure
but I would think the area around the wing root and flap would be different because of the curvature of the 2 different fuselages.
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
05-12-2008, 12:43 PM
Same Wing
The 8 and the 7 use the same wing. The span of the 7 is greater due to the wider fuselage.
Hans
05-12-2008, 01:32 PM
How come the difference in wing area? RV8=116 sq ft and RV7=121 sq ft. Do they count area of the fuselage too?
Project: RV8
Status: Empennage (paused)
05-12-2008, 02:31 PM
Wing area is typically calculated by span * average chord.
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
05-12-2008, 07:32 PM
Hans
They are the same. I have both drawings and the part numbers are identical.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
05-12-2008, 07:55 PM
Wing Differences
Are subtle...and most part numbers are identical. Same tanks, leading edges, and skin dimensions for the wing itself.
The rear spar is trimmed differently at the inboard end (stays full length on the 8).
Main spar center sections are obviously different due to fuselage width.
The inboard bottom right wing skin also has an NACA duct cutout on the 8/8A to provide fresh air to the rear passenger.
The flap ribs are the same, but the flap spar and skins are different to account for the difference in fit required at the fuselage.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
05-13-2008, 01:41 PM
Opulence, I has it...
Couple of more...
Push tubes are different lengths, the flap pushrod connection area is different (can't remember exactly, but remember differences in my construction vs. my usual "go to" web resources--which are -7s)
Joe
Joe Ferraro
DFW, VAF #17
SOLD
05-13-2008, 10:24 PM
Could the smaller RV-8 wing area relate to the specs being developed with the old style wing-tip? The newer tips have significantly more area; see the PIREP in AOPA pilot (I think) on the RV-7 some years ago. Van talks about the extra tip area and the article discusses the difference in span between the two. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
05-14-2008, 04:24 AM
The RV-8 wing area with the old tips was 110 sq. ft.
The standard way to calculate wing area includes the portion of the fuselage that lies between the leading and trailing edge of the wing. That part of the fuselage is wider on the RV-7, so it has more area. This is why the RV-7 has a larger wing area than the RV-8, even though the wing panels are identical.
