Old 05-11-2008, 09:10 PM
Roy Samuelson Roy Samuelson is offline
Default Drilling hole in new front wheel fairing bracket
Is there a good way to drill a 21/32 inch hole in the bracket? I could not find a Unibit with 21/32 inch step.
Thanks for the help
Roy Samuelson
RV7A in Alameda CA
Old 05-13-2008, 07:17 AM
n505at n505at is offline
Default What I did
I used a large Unibit to drill the hole to 5/8 inch. I then used a Dremel with a small sanding drum to enlarge the hole just enough to allow the AN960-616 washer to fit through the hole.
This took about 5 minutes, not a big deal.
Roy
