Old 08-26-2005, 10:00 AM
RV_7A RV_7A is offline
Default Pitot/Static Tube placement?
Can anyone tell me if there would be a problem mounting my Pitot/Static Tube between the 3rd and 4th outboard rib as opposed to next to the Aileron Bellcrank like Vans suggests?
Here
VS Here...
-Jeff
www.JeffsRV-7A.com
N808TX
Old 08-26-2005, 10:05 AM
Mel's Avatar
Mel Mel is offline
Jeff, This should not cause any problems aerodynamically. Do you intend to implement any kind of inspection hole to install/service the connection?
Mel...DAR
