Old 05-11-2008, 08:46 AM
Rockyjs Rockyjs is offline
Default Spell Checker for Kitlog Pro
Has anybody found a spell checker for Kitlog pro .MDB files. I'm getting close to printing my rather large build log, and need to clean it up. I've searched, but can't seem to find one.
Rocky
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
Old 05-11-2008, 12:20 PM
Rivethead Rivethead is offline
You could always copy and paste into Word or Star Office and use their spell checkers.
Old 05-11-2008, 02:52 PM
rfinch rfinch is offline
The .mdb files are simply Microsoft Access database files...and MS Access has a built-in spell checker. So one way to spell check them is to open the kitlog.mdb file from Access (you'll need a computer with MS Office installed). The file is usually found in the directory where kitlog pro is installed.
Once you open the .mdb file from Access, you'll see a list of about two dozen tables. Open work work_logs, click on the comments column to select it, and click the spell check icon. You can spell check other fields, like the picture captions, also. Be careful. If you mess up the other fields you probably won't be able to open it from kitlog pro again. Make a backup of kitlog.mdb first.
Since spell check is built-in to MS Access it would be trivial for the developer to add it to the GUI. Perhaps they will next version and charge $25 for it.
Ralph Finch
Davis, N. California
RV-9A QB Log
Old 05-11-2008, 08:17 PM
Thanks guys! I had tried to paste into word, but lost formatting and picture data. I also have been using Access which works fairly well, but is a bit unstable. I can only get about 3/4 of my build log to load in Access and am attempting to split the log into 2 parts. It would really help to have a spell checker internally in the program.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
