Old 05-10-2008, 07:37 PM
AirbusPilot AirbusPilot is offline
Default Warning-Flop tube!!!!!!!
Hi All,
I need some advices here, I am building and RV-8. Right now I am finishing the fuel tanks, Proseal not a problem but I am not sure about how safe and how necessary is to install the antihang mod to the tanks if you are installing the flop tube. Please check the pictures and see what happens to my flop tube when I rotate the tank, if I do not install the antihang there is no way that the flop tube get stacked anywhere so why vans recommend this mod.
PLEASE CHECK AND ADVICE!!!!!!!!!!!!
Old 05-11-2008, 07:19 AM
panhandler1956's Avatar
Default Interesting
I used a flat piece of aluminum per the plans and I dont see how the end could get underneth it. Your installation definately looks more elegant, but it might lend to this condition.
Just my 2 cents and I am by no means an expert.
Looking forward to others comments.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 05-11-2008, 08:33 AM
frankh's Avatar
frankh frankh is offline
Default I don't like that at all!
I have a 7 so if i remember my anti hang looked different.
No way would I put that in there that way!
Frank
Old 05-11-2008, 09:03 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default I don't have one
I did not install an anti-hang device in mine. Don't remember if it was the length of my tube or shape of the stiffeners or where i put my backflow door, has been too long, but on mine installing the device per plans was not needed. I could rotate the tank in any manner posible and there was no surface for it to catch. So did I did not install it.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 05-11-2008, 09:38 AM
Transporter Transporter is offline
Default Anti-hang
The purpose of the bracket is to keep the flop tube from getting caught in the corner between the stiffener and the rib and to keep it out of the way of the trap door...a much shorter bracket will do the job and won't let the tube get caught under it.
YMMV.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 05-11-2008, 11:00 AM
Flyrod Flyrod is offline
Default One other thing to be careful with......
Before you close up that tank, be extra sure you have done the best job you can on sealing the fuel level sender on the flop tube tank. I would pro-seal the @#$!#$ out of it. If it starts leaking a few years down the road, you cant fix it without taking the tank off!
RV8 "Gladder's Gal" #80707
Superior IO360 B1B 193 HP, Whirlwind 151-69"
IFR-Dual Cheltons, Crossbow NAV 425EX
Garmin 430/SL30/330 Mode-S w/ traffic
Ryan 9900B TCAS, WSI AV300, S-Tec 55X
Searey 80 HP
Old 05-12-2008, 09:24 PM
Today we found the solution for our antihang problem, check the pics
Old 05-13-2008, 02:37 AM
Default Clean tanks!
By the way, you did a nice job on those tanks - looks very clean. Mine look like a pro-seal bomb when off once everything was said and done.
Have fun out there!
Brent Owens
Columbus, OH
N784DE S/N #82614
Old 05-13-2008, 05:56 AM
Have fun out there!
Yes I tried to keep the tanks as clean as I can, I hope they are leak free too will test next week. Look at the picture form the outside very clean.
Old 05-13-2008, 07:13 AM
Jamie's Avatar
Jamie Jamie is offline
Yep, ditto on the pretty tank comments -- very impressive. Mine looked horrible! I'm glad all that Proseal is hidden. ;-)
I don't intend to hijack the thread, but I think people should consider seriously if they will ever need flop tubes. They're useless unless you're going to put in FI and inverted oil. They're just one more thing to break (they're a moving part).
I have the fixed pickup tubes and have all sorts of fun doing acro, including hammerheads and humpty bumps. I don't miss the flop tubes one bit.
