Old 05-09-2008, 02:44 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Where to get these Wire separators
Anyone know where to get wire separators like the black one in this picture?
A couple came with my engine and I'd like to get some more.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 05-09-2008, 03:00 PM
petehowell's Avatar
Default 2 options
Lightspeed Ignitions or Mcmaster-Carr. Speed shops should have them, too.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 05-09-2008, 03:09 PM
SteinAir SteinAir is offline
I've found them at various auto parts stores, or online at:
http://www.partsamerica.com/productd...goryCode=3347D
Not cheap, but they are handy! McMaster might also have them as others have said.
Stein
Old 05-09-2008, 03:43 PM
AltonD's Avatar
AltonD AltonD is offline
$13 for a set of sixteen. That does not sound bad. I must be getting numb to prices. A friend told me "When you get to the end, you will pay whatever you need to pay to finish." I am there.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-09-2008, 09:30 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Those come supplied with Lightspeed Ignition systems. Maybe if you call Klaus at Lightspeed, he'll give you some.
Heinrich Gerhardt
Old 05-09-2008, 10:12 PM
deene deene is offline
Heinrich Gerhardt
Actually, he sells these by the piece...check his website.
When I installed my LS on my 390, the James plenum prevented using the standard top of case mount. I mounted the coils on the motor mount and thus needed one long lead. I bought a universal MSD lead (48") from the local hot rod shot. The lead came with a crimping tool (plastic) which worked well. I salvaged the LS boots from the old lead and all was well.
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 05-10-2008, 07:20 PM
Geoff
Posts: n/a
Default Make your own
Make your own out of two tie-wraps. One around both ignition wires, and one 90 degrees to the first one, wrapped around the first one, in between the two ignition wires. The second tie-wrap serves as the separator between the ignition wires, and the first tie-wrap holds the whole thing together.
