Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 05-08-2008, 12:43 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Default Garmin 396 WX weather question
I'm going to borrow Nordo's 396 for this weekend's flying but when he sold his 8, the new owner still has the GXM30A weather receiver/antenna. I have another (last one, I only have two) friend who is going to loan me his antenna. I can't get hold of Garmin to ask them, so here goes. If my second friend has a current XM weather subscription on his "receiver", will it also show weather on Nordo's 396 or do you have to mate the receiver/antenna with the unit in use??
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 05-08-2008, 12:45 PM
mburch's Avatar
mburch mburch is offline
The subscription lives inside the antenna, and will work with any 396 or 496.
cheers,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 05-08-2008, 12:58 PM
BlackRV7's Avatar
Thank ya, Matt
cheers,
mcb
Dana Overall
Richmond, KY i39
VAF #993
Old 05-08-2008, 06:27 PM
Geico266's Avatar
Geico266 Geico266 is offline
cheers,
mcb
Sorry, but I don't think that is right.
I have heard this before, but it does not hold true with my Garmin 396 & 496. To activate the weather subscription you have to give XM the ID number of the GPS unit, not the antenna. My 496 has a current XM weather subscription. If I take the XM weather antenna and plug it in the 396 it does not recieve XM weather. If I plug any XM Weather antenna into the 496 I have weather.
Edited by Geico266: This info is not correct, read below.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-08-2008, 07:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I have heard this before, but it does not hold true with my Garmin 396 & 496. To activate the weather subscription you have to give XM the ID number of the GPS unit, not the antenna. My 496 has a current XM weather subscription. If I take the XM weather antenna and plug it in the 396 it does not receive XM weather. If I take the 496 and "plug" it into the panel of any plane with an Airgizmo we have weather. If I plug any XM Weather antenna into the 496 I have weather.
The subscription lives with the GPS unit.
Sorry Larry, I have documented proof that Matt is right, at least for the 396's - I have used Louise's XM antenna on my 396, and my XM antenna on hers - they work just fine. They have different subscription levels Full and Lit), and the subscription level goes with the antenna. I'm not sure why it is different for your unit....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-08-2008, 07:35 PM
craigvince's Avatar
craigvince craigvince is offline
Question Antenna
I looked at the back of a 396 today and have a question. The GPS antenna plugs into the BNC connector, but where does the XM antenna plug into? Do the XM antennas come with the 396 or do you have to buy it separately?
I assume the 1/8" connector is for audio out?
Old 05-08-2008, 07:37 PM
Geico266's Avatar
The XM Weather antenna plugs into the USB port just below the power plug. The antenna comes standard with the 496 & 396.
The 1/8" plug is audio out.
Old 05-08-2008, 07:52 PM
Geico266's Avatar
Paul
I stand corrected! I just called XM Weather and the service follows the antenna! I must have a fluke thing going on with my situation. Learn something new every day.
Sorry guys! The service follows the antenna (which is the "Unit ID" displayed in the GPS).
Old 05-08-2008, 08:01 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default mine does
When I subscribed to XM I had to give them my antenna number (on back side of the Antenna) and that's my radio ID on my XM account. Never gave them my 496 number.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 05-08-2008, 08:06 PM
Ironflight's Avatar
Same with me - there are antena serial numbers on the back of both of ours....not trying to be troublesome Larry...
Paul
Paul F. Dye
