Old 05-08-2008, 11:46 AM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Question Do we need "in process" build inspections?
Now that I have started putting together my empennage, a question came to mind. Do I need to have periodic build inspections performed by a inspector throughout the project? Or just have someone look at what I have done and say "yup looks good to me!" I know the airplane has to be inspected by the FAA before it get certificated but I started wondering out of fear of having to disassemble components for inspection. Any words of advice to this newbie builder would be appreciated.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 05-08-2008, 11:56 AM
danielhv's Avatar
danielhv danielhv is offline
I was under the impression that you dont have to.. but it'd be a good idea to anyways just to have an experienced set of eyes look at your work while it is easily accessible. Your local EAA chapter should have some tech counselors that can do this for you as well as get you out of sticky situations! Im sure others will chime in with more accurate info. Good luck.
Old 05-08-2008, 12:00 PM
milt milt is offline
Default Do it
We had an inspection before closing the tail section up completely and then another when we were ready to put the final skins on the wings. Each inspection went well with some suggestions from the inspectors. We had a different inspector each time and each see things different. The inspections are "free" (might offer to buy lunch) and you get a written report of the inspection. When it comes time to get final certification, the final will go much smoother if you can show you had periodical inspections.
We are currently doing the plumbing and will have it looked out before we put the final skin on the fuse and flip it on to the landing gear for the last time.
My 2 cents ...
Milt Atkinson
RV 8 Dad
N218HM Reserved
Emp Done!, Wings Done!,Working on fuse!
Old 05-08-2008, 12:08 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Actually you need neither.
Unless looking at your need requires it. Your need would be too complicated to go through here.
You certainly are not required to have either....which is what Im guessing you meant to ask.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-08-2008, 12:16 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
When I had my inspection, my DAR never asked the first question whether a tech counselor had looked at my airplane. Required, Nope, looked at during inspection, nah, mine wasn't, but YMMV, good to do, can only help if you feel the need.....oh, that need thing again.
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 05-08-2008, 12:41 PM
kentb's Avatar
kentb kentb is offline
Default Dan, they are not required.
They may not even be recommended, if you feel that you are doing as good a job building as possible.
I asked an EAA tech counselor to check my work after my tail was done, before I closed out the wings, and twice during installation of the engine.
My work got better the more building experience that I acquired and I learned a lot from the inspections.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 05-08-2008, 01:11 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Not required, but suggested...
...by the FAA.
Check out AC 20-27F....
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/0ca2845e2aafffbb86256dbf00640cb2/$FILE/AC20-27F.pdf
The following are extracts...
Page 9
(2) The FAA inspector cannot be involved in the building process and will not perform any progressive or in-process inspections during the building process. You should ask a knowledgeable person (for example, an EAA Technical Counselor) to conduct in-process inspections. You should record any such inspections in the aircraft logbook.
Page 10
c. Paperwork Review.
We will review the following information as part of our inspection.
(1) Evidence of inspections, such as construction log entries signed by the amateur builder or other knowledgeable persons (for example, certified mechanics or other builders) or EAA Technical Counselors visit report cards describing any inspections conducted during the construction. Those entries should indicate what was inspected and by whom, and the date of the inspection. Include photographs documenting construction details, if available
A good review of the AC document would probably be worthwhile...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-08-2008, 01:15 PM
allbee allbee is offline
you only need in process inspections if: you are not sure of what you are doing. you are safety concious and want a second opinion on your work. you are flying the airplane, dah you want another person to look at it. I'm doing very good work but I want a second opinion, just so I know it's good to go. As far as the FAA, no you don't need it, you just finish the airplane and call the FAA for an inspect, or a DAR, than go fly it.
Old 05-08-2008, 02:30 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
I have seen so many little things get overlooked over the years (even by A&P's and IA's), that I have come to believe there's only one thing that will suffice for my comfort that things are done right...and that's a second set of eyeballs. The more experience the better, the more looks the better. ymmv
RV7A-QB, RV-10
Old 05-08-2008, 03:28 PM
Mel's Avatar
Mel Mel is offline
Default Required?...No...
Recommended?...STRONGLY!!!
I DO ask to see evidence of periodic inspections. I don't care how conscientious or experienced you are, it is very easy to overlook things when you are close to a project.
If I come out to do a certification inspection and you show me evidence that you had periodic inspections, I'm going to feel much better about you project and your attitude. If you have the attitude that you don't need these inspections, then I'm getting uncomfortable already.
With EAA tech cnslrs doing these inspections for free, there's absolutely no reason not to take advantage of them.
And as someone already said, try to get several different people to inspect. Different eyes see different things.
Even us tech cnslrs get these inspections from others.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
