Peter,
If you are converting back to a fixed pitch, are you going to leave the governor mount on the engine? It's easier to install the cover plate after removing all that excess weight from your engine.
You can get the cover plate from ECI at
www.eci2fly.com
If you don't have a parts manual, let me know. I can look it up for you when I'm at home. Hard at work right now!
