Old 05-08-2008, 02:17 AM
Mario Pons Mario Pons is offline
Default Fuel pump and Infinity stick grip
Hello. Two questions :
#1 I want install a Facet electric pump for my Lyc from Aircraft Spruce but I see different models ( antishiphoning valve or not ). Which of them ?
#2 I purchased a Infinity stick grip and one of the possibles aplications is engine start ( green button ). Its a good idea ?
Thanks in advance.
Mario. RV3B
Old 05-08-2008, 04:05 AM
cholladay cholladay is offline
I am finishing my RV-8 this month. I Have both my start and fuel pump on the infinity stick. I also have a master disconnect switch on the panel so I can arm and disarm the the fuel pump or the starter on the stick in either the front or the back locations. I did the disconnect switch on the advice of others so the button would not be pushed accidently in the air.
Live Strong
Chad
Old 05-08-2008, 06:29 AM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
Default Isolate switch
I liked the infinity's I put on an RV-7, they fell like a million bucks and only cost $450!
You really need a stick isolate switch on the panel, use a locking minuter switch that has a center OFF position. ON-OFF-ON.
Take the plastic cap of the switch so you have to dig into the switch a little bit to activate it. You will also want to do this with your fuel pump as it will be a latching switch.
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
Old 05-08-2008, 09:49 AM
frankh's Avatar
frankh frankh is offline
Default I don't think you need it
The wing tanks are almost at the same level as the carb so I doubt it would make any difference.
The float valve would have to leak for any fuel to flow anyway.
Those pumps are also available at your local automotive store.
Frank
