Old 05-07-2008, 06:03 AM
dan carley dan carley is offline
Default oil pressure
i've reciently purchased a nice rv-4, on it's first long flight i noticed the oil pressure gauge jumping from 40 to 60 lbs. after a few minutes it stabled about 60lbs. it is a westtack electrical gauge. could it be the oil pressure is fluxuating? would it be the gauge,wiring,sender or a bad ground?
thanks
dan carley
RV4
N14FT
Old 05-07-2008, 08:08 AM
asav8tor asav8tor is offline
http://www.sacskyranch.com/eng169.htm
Old 05-07-2008, 08:25 AM
Shine'r Shine'r is offline
Dan the answer is "YES" to all the above. The first thing I would do is hook up a mechanical pressure gage and see what the reading is. You could put a "Y" into the line before the sending unit and even run it into the cabin if you want to fly with it. You need to know if the pressure is really fluctuating (jumping) before you start tearing things apart.
Shine'r (Flying Slooowly over the western Pa country side)
Old 05-07-2008, 09:38 AM
Allen Barrett Allen Barrett is offline
Dan, after you verify the guage and plumbing, check the oil pressure relief valve seat. Many times there has been a nic or piece of trash embedded and will hold the 1028-B ball off the seat causing a hyper O/P reading
Allen
BPE, Inc
Old 05-07-2008, 09:46 AM
i just looked at the unit, i found a small amount of oil on the back of the sender, could this be the problem? i think i'll tee off and put a regular oil gauge in line. just for my own piece of mind.
danny
