08-25-2005, 10:13 AM
How do I squeeze tip rivets on elevator
Just about ready to finish the elevators on my RV9.
How in the world do I get a buck bar behind the last two rivets on the trailing edge of the root and tip ribs? There just isn't any room in there for my pneumatic squeezer or any buck bar I have seen?
What did you all do????
Duane
08-25-2005, 10:46 AM
There are a few ways
Duane,
Do a search of these pages, this topic has come up before.
There is a picture of how I did it on the bottom of my aileron web page.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
08-25-2005, 01:08 PM
A "no hole" yoke on the squeezer works great for this.
If you can borrow one from a local builder you can squeeze them all in a few minutes.
08-25-2005, 02:21 PM
unqualified unfluencer
Hey Duane,
I used flush pop rivets on those last two holes...
Best,
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Part time: Supporting Crew Member CAE Embraer Phenom 300 (E55P) @ KDFW.
- Occasionally: Contract pilot (resume).
08-25-2005, 03:49 PM
Originally Posted by DeltaRomeo
Hey Duane,
Best,
Thanks Doug,
Bit I don't know what "flush" pop rivets are. Are these standard "blind" rivets set in countersunk holes? Or are they a different beast altogether?
Duane
08-25-2005, 04:31 PM
Duane
Yes, countersunk. See.....it's been a few years and I have already forgotten the name <grin>. I tried (like many) to buck 'em or come up with some fancy way to squeeze 'em.
After talking with some that are repeat builders I took their advice: pop rivet. No one will ever see it.
Best,
08-25-2005, 04:43 PM
Pretty sure Van specs out CS-4-4's there.
I am sure you have them with your kit.
Personally, the no hole yoke is my weapon of choice.
Reeeeeaaaally slick!
 CJ
The experiment works!
08-25-2005, 05:08 PM
The thin nosed no-hole squeezer yoke will do most. I used the MK-319-BS pulled rivets in a few places. Unlike the CS4-4's, they will fit into the same countersink as the regular -3 solid rivet.
William
RV-8QB just finished the empannage
08-25-2005, 05:31 PM
Ummm yah... but now for the $20 question,
Which one (if not both) is/are a structural fastener?
First of all, I know it kinda doesn't matter and second of all...
I HAVEN'T GOT A CLUE!
 CJ
08-25-2005, 09:27 PM
Elevator TE rivets
 CJ
All rivets are structural fasteners (even pop rivets). The question is what loads can each type withstand. The loads on those rivets (at the TE of the elevator tip) are so low, it doesn't matter.
If I ever do this again, I will smear some JB Weld (or ProSeal) from the last drivable rivet to the end of the rib (after proper prep of course) and called it a done deal (then just fill the hole like you would a pop rivet).
I was able to drive solid rivets using a flat brick chisel (happened to have one laying around). I actually back-riveted them by laying the flush head on a back-rivet plate then sliding the chisel in against the rivet and used the rivet gun on the chisel. It was ugly but it worked.
Dennis Glaeser
7A Wings
