Old 05-05-2008, 06:52 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Mag Switch Wiring Check?
I'm checking the wiring of my mags and mag switch with an ohm meter and in all ignition switch positions, OFF/L/R/BOTH, there is low resistance to ground of ~1 ohm. If I disconnect the mag leads from the switch and the little jumper bar for the impulse mag then the terminals read as they should - both grounded in the OFF position, both infinite resistance in the BOTH position and alternating in the L & R positions.
I'm a Mech. Eng. so can any of you spark chasers out there help me understand what I'm missing? What should the connection at the mags look like? There is a big phenolic washer and a shiny tinned surface at the mag lead connection. Where does the lug go relative to these?
Thanks in advance.
Jim Sharkey
RV6 - Wiring
Old 05-05-2008, 10:45 PM
elippse elippse is offline
Thanks in advance.
Jim Sharkey
RV6 - Wiring
The mag "P" lead is across the beaker points, so if the points are closed you will read the short across the points plus the wiring resistance. If the points are open you will read the coil primary resistance which is probably about 0.5 ohm to 1 ohm.
Old 05-05-2008, 11:46 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Previous posting
This posting might be of some help.... gil A
http://www.vansairforce.com/communit...ght=mag+p-lead
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-06-2008, 05:25 AM
jsharkey's Avatar
Thanks Gil and Elippse.
Jim
Old 05-06-2008, 03:47 PM
jsharkey's Avatar
Found this neat page on the web too. Virtual magneto assembly.
http://www.undaerospace.com/cbt_file...l%20Engine.swf
Jim Sharkey
