Originally Posted by Brantel
Anyone have a PDF or readable pictures/scans of the documents & drawings that come with the FWF kit? I am needing some of the details on this as I have purchased much of this stuff in advance. Don't need the baffle documents, just the other stuff.
Brian,
Was in the same fix. You can order separately the FWF plans from Van's, doubt if anyone has pdf since they are same size as full size plans, DOC FWF COMPLETE put in the 'search' at the bottom of the web store and they will come up. Really cleared the air on some things that I was unsure about, worth the money.
Good luck,
Mike H 9A/8a
