Old 05-04-2008, 09:16 PM
rwarre rwarre is offline
Default fuel tank leak
Having trouble finding the leak in my right fuel tank. Used the manometer method and the balloon. Have tape over the gas cap. I have sprayed the tank with soapy water, used a brush to brush on the soluton, and tried to listen/feel where air might be escaping. No luck. Has anyone pressurized the tank and set it in water, like a bathtub. Tires are done this way. My soap solution is 7 to 1 recommended by a plummer. When I use the manometer method, the water level starts going down immediately very slowly.
Old 05-04-2008, 11:47 PM
Pirkka Pirkka is offline
Manometer and it's connections/connectors are leak-proof? Trying to put tank in to water sound like too complicated. Soapy water should do just fine -- try once more? Get friend to look with you -- you are already too tired to look carefully enough. From Van'sairforce.net you can look for another threads where the obvious leaks are but I think to save time just go and test your tank more: connectors especially.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 05-04-2008, 11:56 PM
Pilottonny Pilottonny is offline
Default Fill the tank!
I tested the tanks with 10 liters of fuel, worked fine. When you close the cap, the fuel will pressurise itself, any leaks show-up immediately. Just turn the tank around and leave it in each position for a few minutes, so that the gas has reached all the internal surfaces of the tank.
Always be carefull with gas, though!
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 05-05-2008, 04:58 AM
tinman tinman is offline
Add some ultraviolet tracer dye in the fuel when testing. Sometimes the leak isn't really a leak...more like a weep. The dye will leave a trace behind after the fuel evaporates. The local auto parts store should have it for around $8 per bottle.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 05-05-2008, 08:35 AM
N941WR's Avatar
N941WR N941WR is offline
Have you put fuel lube on the fuel cap O-ring? They tend to leak in the test.
I would put fuel in the tank as a last resort as you will have to clean it out to fix the leak.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-05-2008, 12:43 PM
RV7Builder RV7Builder is offline
I took my tank out to our pond, tossed it in and sat on top of it. I still had the manometer hooked up with water in it. I was able to maintain a slightly positive pressure by manipulating the tube. The leak I couldn't find with soapy water showed up immediately. It was in my manometer connections...
Eric
RV-7, Constructing fuselage bulkheads
1946 Cessna 140
Old 05-05-2008, 06:03 PM
Jeff R's Avatar
Jeff R Jeff R is offline
As Bill said, check the fuel cap. I had a really small leak there that was hard to see with the soapy water.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 05-05-2008, 07:05 PM
Aden Rich Aden Rich is offline
Default Tank leak
The submersion in water is best. Your local tire dealer should have tank filled with water to check for leaks. You could take it there or like the one guy said, throw it in a pond and lay on it. I had a leak up in the very top outboard corner that took forever to find. It would only leak when the tank was totally full and in the taildragger mode. If I ran any level out of the tank it wouldn't show up.
Old 05-06-2008, 10:55 AM
664781 664781 is offline
Default Leak Check
I put both my tanks in my pool to leak check via the ballon method. Found the caps leaking thru the center o-rings. Worked great!
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
