Old 05-04-2008, 01:58 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Primer Solenoid Testing?
I'm testing my electrical system and was expecting a click or a clunk when I energized the primer solenoid but can't detect anything. Everything checks out with a meter. Just no indication that it is functioning. Anyone else got any experience with them?
Jim Sharkey
RV6 - Wiring
Old 05-04-2008, 02:31 PM
Default That's Good Enough for easy Function Testing
When you use the system you can verify that it works just with engine starting ease. You can do a two person required test where you turn on the aux. pump to pressurise the system with a primer line disconnected at a cylinder and verify that no fuel comes out, press the primer momentary switch, verify that fuel comes out, release it and verify that the fuel flow stops but I just did the same test you did and went with it as verifying port opening with power application. If operation proved there was a problem I would have proceded with trouble shooting but that didn't happen - the primer solenoid worked as expected.
Bob Axsom
Old 05-04-2008, 03:07 PM
vansrv8's Avatar
vansrv8 vansrv8 is offline
Mine (from Vans) makes a pretty loud clunk when energized...
Ken Tattersall
Kens RV8
RV8, Pitts S1C,J5 Hybrid,AcroSport II
Old 05-04-2008, 03:28 PM
jsharkey's Avatar
Thanks - that's what I expected. I need to do some trouble shooting.
Jim
Old 05-05-2008, 05:49 AM
pierre smith's Avatar
Default Wiring
Hi Jim, we also wired our primer pushbutton from the fuel pump switch so that it's only supplied with power while the fuel pump is on. This way you can't flood the engine in flight if the primer is accidentally pushed to on.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-05-2008, 06:58 AM
N395V's Avatar
N395V N395V is offline
Jim
Mine is silent but works just fine.
Milt Concannon
Old 05-05-2008, 07:32 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Im not sure I have ever "heard of a silent solenoid". Seriously. All solenoids of this type should click. You should hear it and feel it.
Now you might not hear it over other stuff like gyros spinning up or fuel pumps running. But if you just testing the solenoid, that thing should be heard from 50 feet away.
Its just a big relay that uses electromagnets to activate big contactors. When the contactors hit, its noisy, at least it should be. Even the tinyiest of relays that can fit on your finger tip, click and make noises. Perhaps micro relays cant be heard by the humad ear unassisted. I dunno.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 05-05-2008, 09:32 AM
jsharkey's Avatar
Regards,
Yes - that's the way it's wired. I disconnected the pump to test the solenoid because it creates a racket when working dry. Hopefully it's quieter with fuel in it.
Jim
Old 05-05-2008, 09:52 AM
647jc's Avatar
647jc 647jc is offline
I have a similar configuration and also disconnected my fuel pump to verify the primer solenoid activates. Yes, I definitely hear a clunk when I push the primer button, not as loud as the master or starter solenoid but a definite clunk.
I assume your wiring has 12 volts coming to the primer button from the switch that turns on your fuel pump. Also, the primer button should then provide 12 volts to the primer solenoid when the button is pushed. The other side of the solenoid should be connected to ground. It?s possible the primer solenoid plunger is stuck in which case you would not hear a clunk. You can verify the wiring by verifying the magnetic coil of the solenoid by holding a small screw driver close to the solenoid and have someone push the primer button. You should be able to detect the solenoid becoming magnetic when the button is pushed. If the solenoid becomes magnetic and still no clunk, you should be able to disassemble the primer solenoid valve assembly and determine if the plunger is indeed stuck and possibly free it up.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 05-05-2008, 10:47 AM
jsharkey's Avatar
I assume your wiring has 12 volts coming to the primer button from the switch that turns on your fuel pump. Also, the primer button should then provide 12 volts to the primer solenoid when the button is pushed. The other side of the solenoid should be connected to ground. It’s possible the primer solenoid plunger is stuck in which case you would not hear a clunk. You can verify the wiring by verifying the magnetic coil of the solenoid by holding a small screw driver close to the solenoid and have someone push the primer button. You should be able to detect the solenoid becoming magnetic when the button is pushed. If the solenoid becomes magnetic and still no clunk, you should be able to disassemble the primer solenoid valve assembly and determine if the plunger is indeed stuck and possibly free it up.
Good idea to check if it's magnetized. I'll do that before tearing things apart.
Jim Sharkey
PS - Is the solenoid polarized? Could I have it wired backwards? The leads were the same color with no one obviously meant for ground.
