Old 05-03-2008, 09:29 AM
prkaye prkaye is offline
Default gear mount - floor stiffener intereference
Did any 9A/7A builders find the flange of the floor stiffener interefered with part of hte gear mount that bolts to the center section (the arm that extends inboard and then 2 bolts to the center section there... this little piece won't line up with the holes because the floor rib flange is blocking it).
I see two options... one trim the material on hte gear mount, or two try to get a little dremel wheel or something in there to trim back that floor stiffener.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 05-03-2008, 06:36 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I had a pretty tight fit on one side, but it made it. I almost thought that I would have to do as you suggest.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 05-03-2008, 06:41 PM
cleve_thompson's Avatar
cleve_thompson cleve_thompson is offline
I had the same problem on the right gear and used a flat "needle" file (I think that is the name of the little thin files) to file the gap at the end of the stiffener wider. It took a while but I thought that it was the safest tool to use. The left side fit OK, thank goodness.
Cleve Thompson
Waycross, GA
Flying a RV9A with O-320 from KAYS
since Dec 2007 & having a blast
Old 05-03-2008, 07:51 PM
Rupester Rupester is offline
Thumbs up
As someone else said ... mine fit very tightly, but required no grinding or modifications. Once the weldments were in, I marveled yet again at how extraordinarily well designed and fabricated the Vans kits are.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
