Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 05-04-2008, 06:50 AM
panhandler1956's Avatar
Originally Posted by captainron View Post
BTW, shouldn't the low pitch stops keep the RPMs at a safe level even if the governor falls off the airplane?
Ron,
You make a great point. I have personally experienced a governor failure on a non-RV with an alternative powerplant (Chevy V-8) with a custom propellor (MT made it for us to spec) that rendered the aircraft a glider.
I made it back to the airport, but we learned the manufacturer set the fine pitch stops to a position that would not make enough thrust to fly the airplane. The mechanic adjusted the prop and we tested it thoroughly with and without the governor.
Moral of the story - Props that are designed for RVs should be set appropriately at the factory, but I would(will) verify before installation.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
