Originally Posted by Steve Sampson
I ordered 80 off AN507-632-R8 screws expecting to recieve cadmium plated. The supplier has shipped some that are flat grey (carbon steel?). Does anyone know what the spec for AN507 is. Did I order wrongly or have I been supplied wrongly. How is the cad plating specified?
Thanks, Steve.
Steve.. they got replaced by MS24693 screws... the later spec is here...
http://www.av8design.com/Hardware/MS24693.pdf
It does call out the type of cad. plating required... but I don't have a copy of that spec. - but most AN hardware does call out a gold iridite final finish on cad plating.
Can the screws be picked up with a magnet? Perhaps you got SS ones?
Would it be Better to order them with the MS part number?
gil A
UPDATE
It appears the QQ-P-416 does require a color after plating (unless otherwise specified, which is not the case)
http://www.techplate.com/cadmium.htm
"Unless otherwise specified, chromate treatment required for Type II is distinctly colored iridescent bronze to brown including olive drab, yellow and forest green"
Perhaps the EU got to your screws and banned cadmium plating, and you have equivalent screws with some other coating?
