Originally Posted by rv6ejguy
The CMARC CFA plots on my 6A show lots of bad stuff in this area so this would be a place to clean up aerodynamically. If you like composites or can come up with flexible fairings, there might be some gains here.
Can you post those plots? Thanks George
The recent movie about Howard Hughes has a scene where he looks down the side of the plane and says "I want all these rivets flush". You can just look at your airplane and see the drag if you try. Every little bump, mismatched edge, protrusion that is not removed or faired in is drag. The rudder horn is drag but the airflow is turbulent back there and is not as critical, but every little bit counts. One RV builder made the rudder control and horn totally internal!. Not sure how it worked but it was clean. For the RV the single greatest drag maker is cooling drag, which can add 7-10 miles per hour. Cheers George
