Old 04-30-2008, 07:18 PM
TerryWighs TerryWighs is offline
Default Wing spar/rib riveting
Hi all...
Have just started riveting the ribs to the main spar (RV-8). I noticed on the Fore side of the spar where the shop head is being formed, very tiny "fan/hairline stress marks in the anodized finish of the spar. Is this a normal result of the force from the process, or am I doing something wrong. The spar is reasonalbly secured, and the psi is set at 45 (4-5 rivet). Thanks
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 04-30-2008, 08:08 PM
Captain Avgas Captain Avgas is offline
Originally Posted by TerryWighs View Post
Hi all...
This topic has been dealt with numerous times and at length. In fact it is the subject of a CURRENT thread and has been discussed in the last few days. Go to http://www.vansairforce.com/communit...ad.php?t=29429
I highly recommend you learn how to use the Search function at the top of this page. Most questions that builders ask on VansAirforce have been extensively discussed in the past.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 04-30-2008, 10:13 PM
Thanks Bob for the heads-up on the thread...I do know how to search the threads, but apparently did not use the correct "key" words to call up recent/past discussions???
Fairbanks, Alaska
empennage done
Wings done
Old 04-30-2008, 10:28 PM
JHines JHines is offline
The forum search engine is just not very good...the "stop words" especially are too restrictive.
Doug Reeves is testing a Google-based search link. I've tried it and it seems to work a good deal better:
http://www.vansairforce.net/searchtest.htm
Jonathan Hines
Charlotte, NC
