Frustrating
Fitting the cables is a little frustrating. I'd be curious as to how many cables get returned for new ones and how many times!!!! I had two exchanges. My neighbor is on three.
I agree with Paul. You need a compromise between to tight and to loose. If the linkage is tight, you are risking binding and potential chafing and breakage. Remember this is a cable inside there. To loose and the arcs will eat up the travel and you may not be able to get full throw.
I can't get the big photo to open either, but from what I can see, I'd say a couple of inches longer on the cable will give you some latitude for fastening without binding.
It goes without saying, that this is an area that needs to be as perfect as possible.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
