Old 04-28-2008, 06:19 AM
danielhv's Avatar
danielhv danielhv is offline
Default Building a tank... need a size
Im having a tank made at a friends sheet metal shop for dipping my parts in alodine. Can anybody tell me what the longest and widest parts are on a 7/7A? I really prefer the dip method as it looks like it coats MUCH better. This tank will be long and shallow with a drain valve to drain the alodine back into a container for storage.
Old 04-28-2008, 07:53 AM
Tbone's Avatar
Tbone Tbone is offline
Not sure about the slow build version, but on my 7QB I used a 8 in plastic pipe with caps on each end. I then cut an opening down the side and It resembles something akin to a trough. It has worked fine on all of the parts so far. If you are to build a metal tank I would make it at least 6ft x 8" x 8". Make sure that the metal will not be affected by your alodine mix.
___________
Terry
RV7
XP IO360
Old 04-28-2008, 01:00 PM
Transporter Transporter is offline
Default Alodine Tub(s)
I wouldn't make too big a tub/tank since you'd need a lot of product to get coverage and would probably end up with more overall waste. If you want to go this route you could use the wing spar crate; put a moveable divider in it and line it with heavy plastic sheeting as needed for shorter or longer parts.
I use a standard plastic dishpan for small parts and a large (106 qt) clear plastic tub from the local Ace Hardware for larger parts. The large tub is made by Sterilite and will hold two main wing ribs side by side (measures 29" long by 16" wide at the bottom).
I fill either tub just enough to cover the parts (usually about 2") and recycle the used Alodine 1201 (dip with a plastic measuring cup and pour into the used product jug, followed by a funnel for the small amount that remains).
For larger parts (spars, etc.) I use a kitchen-size celulose sponge; while the coating is not as uniform as the coating on parts that have been submersed, this is not a problem according to the Technical Process Bulletin. See:
http://www.henkelaero.com/Images/Dat...ne_120_kit.pdf
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 04-28-2008, 02:12 PM
Norman CYYJ Norman CYYJ is online now
Use small plastic bags for most of the small parts and get some long narrow tube type bags for the long parts. Less chemical needed. Just like marinating a steak or some other piece of meat. Complete submersion is easy with the air taken out of the bag.
Old 04-29-2008, 04:07 AM
skyyking56 skyyking56 is offline
Default Down Spout
I took a 4" x 6" x 10 foot down spout from Menards and sliced it down the middle of the wide dimension and crimped the edges so it wouldnt cut me then bent the height of the sides a little so it would be even a little wider...then I lay in the sheet of thick plastic the entire length and it has worked good except when you drain it out you have to do it very carefully not to spill...I dont think I had to put any more than about 1 1/2 gallon at any time to do the spars.
Hope this helps.
Jim 7A Tanks
Someone might want to add something else for a fuse part..I've only done up to wing parts
Old 04-29-2008, 07:29 PM
Webb's Avatar
Webb Webb is offline
Default soak paper towels
My old A&P used to soak a paper towel and lay it on a big sheet of aluminum. He then would put a new towel on another area. Darn it if didn't do a good job. Problem is you had to do it a few times to cover a big area.
Man was tighter than tree bark and but he liked the method because of less waste.
