Old 04-27-2008, 07:13 PM
dustman dustman is offline
Default aileron wingtip alignment
Help! my wingtip and aileron will not line up. I can take a straight edge lay it on the top of the wing and then align aileron to the straight edge, This process aligns aileron and wing, but the aileron is higher than the top of the wingtip. This condition exsists on both wings. What am i doing wrong? I sure can use some help on this folks.
Old 04-27-2008, 07:14 PM
Default aileron
It's and rv3
Old 04-27-2008, 07:18 PM
Your post doesn't indicate which model you are building, but the general idea is to use the tooling holes in the wing end rib to set the alignment of your ailerons and flaps, then fit the tip to match.
Here's how:
Attach the ailerons and flaps, then run a strait edge along the tooling holes on the end rib. Clamp the strait edge in place, then align the aileron where the tooling holes in its rib match the line established by the strait edge. That sets the aileron. Set the flap to match.
Then, find a way to hold the aileron and flap in position and fit the wing tip to match.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-27-2008, 07:29 PM
frankh's Avatar
frankh frankh is offline
Default Easy
As long as you have the aileron alingned with the tooling holes and the flap aligned with the alileron then.....
Thake a hack saw blade or similar and slit the wingtip along the back edge...i.e seperate the lower surface from the upper.
Mix up some flox and resin and glue the surfaces back together with the tip aligned with the aileron.
A lot of us have to do this and its an easy fix.
Frank
Old 04-27-2008, 09:21 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default -7 dwg 12A differs slightly
Here's how:
My drawing says to line up the aileron tip with the wing rib tool holes but to ignore the holes in the aileron rib.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
