Old 04-26-2008, 02:35 PM
sglynn's Avatar
sglynn sglynn is offline
Default Measuring Edge Distance
Is edge margin distance measured from the center of the hole to edge or the perimeter of the hole to edge when checking to ensure minimum distance has been met?
Old 04-26-2008, 02:53 PM
G-force's Avatar
G-force G-force is offline
Edge of material to the center of the hole.
Mike Sumner
Castaic, Ca
Old 04-28-2008, 03:22 AM
Pirkka Pirkka is offline
Ooh... I'd say it depends how your "minumun edge distance" is specified. I have run to rules which measure it from the center of the hole but also rules which define it from the edge of the hole -- needless to say that minimum edge distance requirement is .5 diam. of the rivet different...
I would use only tables for edge distances, which indicate where this should be measured like: http://home.earthlink.net/~gilalex/r...ec/rivet_a.htm
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 04-28-2008, 07:46 AM
SvingenB SvingenB is offline
Those tables give the absolute minimum. One should also account for repair with oversized rivets giving a limit of roughly 2. The Jeppeson repair manual say min 2, max 4 and nominal 2.5.
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
