Go Back   VAF Forums > Education > Flight Testing
  #11
Old 04-24-2008, 09:54 AM
Bill Dicus Bill Dicus is offline
Default Spin video
Nice video; thanks for the effort to do it and post. I wasn't able to keep track of all pitch changes leading up to the stall break or spin entry, so my impressions include some guesswork. I think the tendancy to go inverted in the first half turn may come from forcing the entry a little - i.e. hitting full rudder before the stall break has allowed the nose to "break" the horizon. Sometimes there is a natural input to increase AOA just before or at the time you expect a break to occur, producing a slight accelerated stall. This seems to be associated with a more vigorous entry and more initial roll. In IAC competition you are downgraded for this type of entry. Judges like to see the nose break through the horizon before any turn or rotation occurs. Trying this in the RV-8 owned by Wendell Foltz (delaying rudder input until nose has passed thru horizon) resulted in smooth gentle entry with no tendancy to go inverted. Try that and see if it yields a different entry. By the way, it ooked as though those two turn spins went more than two! Thanks again and keep us informed on spin behavior at various CG's and weights. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 04-24-2008, 10:07 AM
N733JJ N733JJ is offline
Default spin vs snap
Carl,
I spin my 8 on a regular basis. I have also spun a 6 and 6A.
The primary reason you are rolling inverted on your spin entries is because you are initialting the spin prior to the stall, almost a snap roll. If you wait until the buffet (I realize there is very little) or the break, you will not roll over the top as you have been.
Scott A. Jordan
N733JJ
725 hours
Old 04-24-2008, 02:34 PM
zkvii's Avatar
zkvii zkvii is offline
Default Spin entry
OK - that would sort of tally. I've actually got quite a lot of specific data from the GRT but it is difficult to really visualise it. The google earth render is pretty detailed - the attitude info is very accurate, the GPS lat/long and movement suffers from only being 1Hz (alot of movement in 1 secs)
So competition entry is? from the nose level with horizon with rudder netrual and as through the buffet and as a wing starts to drop, then rudder? Or starting with a more nose up attitude?
Thanks Scott, I tried one yesterday at 55kts but was well forward CofG and seemed to be worse - hence some of the questioning..... What speeds are you using in the 8?
2 Turn - is 2 turn until initiating recovery, ends up being about 2 2/3.
Thanks for the input,
Carl
ZK-VII - RV 7A - New Zealand - NZNE - 700 hrs (2008 -2020)
http://www.rvproject.gen.nz/
TMX OF-360 (FADEC), Dual GRT H1, Garmin 430 / SL30 / 327, TT VSVG
Old 04-24-2008, 02:41 PM
frankh's Avatar
frankh frankh is offline
Default Spin video
http://youtube.com/watch?v=rK5DiNyEuzQ
This one shows a 5.5 turn upright spin in a 7a with large rudder...Oh and opposite aileron to provoke it a little.
Frank
Old 04-24-2008, 05:25 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Nice video, thanks. Looks like you went negative g on the last recovery(?) Was that the low oil pressure annunciator that lit up?
Mike W
Venice, FL
N164WM
Old 04-24-2008, 05:40 PM
zkvii's Avatar
Default Christmas tree lights
Hi - not sure which lights went on, but probably EIS (red on the LHS) (oil or fuel pressure). The other possibles are in the center locations fuel pump (FADEC auto for low pressure), Mute light would be on for the AoA disable, MFD alert for EIS also, GPS possibly just as a airspace alert. I think it was only transitant - could have been fuel sloshing around causing min fuel on the EIS.
Just looked at the logs, Oil pressure went from 69 psi to 37 psi during the 2+ turn spin just after getting to a low of .2 G. Fuel pressure was pretty stable at 36 psia the whole way through just on engine pump.
Carl
Old 04-24-2008, 07:31 PM
Default Competion spins
I too, generaly do "competition spins". A normal unaccelerated stall and full rudder just as the nose drops. I'm not looking at the speed (and it would be different for every plane due to instrument and installation errors anyway) but the AOA is screaming "ANGLE, ANGLE, PUSH" just as it did in your stalls on the video. The fun part is pushing to the viertical down after the spin and adding full power to set up for the next manuver (1/2 Cuban in Primary).
P.S. I forgot to compliment you on the video. Well done and it can be used to help ease the anxiety of others exploring spins.
Scott A. Jordan
Old 04-24-2008, 09:52 PM
MCA's Avatar
MCA MCA is offline
Hard to tell exactly from the video, but if the AOA is too loud there is a volume control potentiometer in the AOA box...
Nice video, spring is here and the smell of spins is in the air again!
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 04-25-2008, 12:33 AM
zkvii's Avatar
Default AoA
Thank you - and you are welcome. I know I watched Dan C's spins before doing this and it helped get some idea of what to expect. Spins in themselves aren't a big problem - it is all about preparedness, practice and training IMHO.
Hi Mark - yes the AoA is 'believably loud' as opposed to 'unbelievably loud' It cuts through everything, radio / ICS etc nicely though. The video audio levels as mentioned previously also overload a bit quickly.
Regards,
Carl
Old 04-25-2008, 12:53 AM
When I competed the judges liked to see level flight with slowly increasing pitch attitude (AOA) with no turn or bank until the nose drops through the horizon as the stall occurs; only then should rudder be added (maybe a little aileron to help begin roll) to initiate the spin. Use rudder and aileron as necessary to keep heading stable until the nose drops through the horizon. Resulting entry usually seems gentle. Forget the GRT and look outside the airplane. Hope this works for you. Bill
Bill Dicus
