Old 04-23-2008, 09:04 PM
Scott Chastain's Avatar
Scott Chastain Scott Chastain is offline
Default Hooker Harness Bushings
"Behold, I send my messenger,
And he will prepare the way before me.
And the Lord whom you seek
Will suddenly come to His temple,
Even the messenger of the covenant
In whom you delight.
Behold, he is coming,"
Says the Lord of hosts.
Malachi 3:1
Scott Chastain
RV-8 N898W Descending Dove
Old 04-23-2008, 09:22 PM
Jim P's Avatar
Jim P Jim P is offline
Is this for the crotch strap? Grind away. No problem. I ran into this with the crotch straps and was able to grind these down, no problem. They might spin, but mine didn't fall out.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 04-23-2008, 10:26 PM
Jim P's Avatar
You got me on the -8. On my -7, the shoulder straps work great on the cables to the rear fuse. I need to check the hip belts this weekend but I hope they fit.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 04-23-2008, 10:52 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default S-bends
I actually put S-bends into all my brackets so they accept the hookers...
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 04-23-2008, 11:51 PM
Default Scott
The way to solve this is to flare out the ends of the bushings. Install your largest fatest male dimple die into your D-2 dimpler (everyone owns one of these right?) Insert the bushing and pull down. You should squeeze one side at a time. Just enough so the bushing fits between the crotch strap brackets. You may have to ream out the bushing a little to fit the AN bolt size call out.
Happy building!
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Last edited by lorne green : 04-23-2008 at 11:55 PM. Reason: Don't remember how to spell.
