Old 04-21-2008, 09:49 AM
Jim P's Avatar
Jim P Jim P is offline
Default Registration Holders
Does anyone know of a supplier for aircraft registration holders for cockpit display? I couldn't find one at AS&S.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 04-21-2008, 09:58 AM
n815vp n815vp is offline
Default registration holders
A ziplock bag with a small strip of velcro is the way I'm going.Gotta save $ for the big things.
Old 04-21-2008, 10:14 AM
jthocker's Avatar
jthocker jthocker is offline
It's tough to find at Spruce but they have them. Called "License Holder", but searching that won't find it. Look under 'Pilot Supplies" then "cockpit accessories" scroll down to find License Holder.
Good Luck
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 04-21-2008, 10:15 AM
WilburD2 WilburD2 is offline
Default El Cheapo..
1/8th plexiglass cut to shape, with .040 'c' shaped standoff around the border, pop riveted to another scrap piece of aluminum then pop riveted into position in the cockpit. Paint the metal to match your interior.
Or:
http://www.wicksaircraft.com/catalog...276/index.html
Bill S.
A+P, RV Dreamer + Schemer
RV-9 preplans in hand
Old 04-21-2008, 11:56 AM
Jim P's Avatar
Thanks Bill, looking at Wicks and AS$S, I think I'll make my own.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 04-21-2008, 05:13 PM
rv8guy's Avatar
rv8guy rv8guy is offline
Wal Mart automotive section
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 04-21-2008, 07:38 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default check
check Walgreens for photo holders, clear plastic type for 4x6 pictures work well to hold certificates
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 04-21-2008, 09:40 PM
MacNab's Avatar
MacNab MacNab is offline
http://www.aircraftspruce.com/catalo...ense_holdr.php
Our DVT pilot shop also has them made locally. It's a 5X7 cordura pouch with a vinyl face and a zipper closure on top. It can be mounted with velcro or the supplied metal clip (or you can add screw grommets to it). Very nice, and about twelve bucks.
Doug
RV-6, AT-301, G-164, C-188...
Old 04-22-2008, 12:19 AM
SebsRV7A SebsRV7A is offline
Default Fed Ex Label Holder
I took a Fed Ex Label Holder and cut it in half. Self stick, cheap, and has lasted the past year. Thin and light, too!
Sebastian Trost
RV-7A
Old 04-22-2008, 12:59 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I used a clear plastic tube made to slip over fluorescent tubes as an anti-shatter device and found some vinyl caps to seal the ends. I wedged it vertically between the seat back support cross member and the flap mechanism cover in the baggage compartment of my -6. I'll try to post a pic later if y'all are interested.
Heinrich Gerhardt
