Originally Posted by AltonD
Lo is ground
IIRC, Lo is the ground provided internally inside electronic boxes like radios and intercoms etc.
By using a local ground instead of the Lo line, you increase your chances of inducing a ground loop, and noise into the audio system.
Re read my prior post-------PTT to Lo, not PTT to ground.
Also, unless the radio and intercom are completely hooked up, you may not be able to trace out the Lo line with an ohm meter, as the Lo circuit passes through some intercoms---------as I found out when hooking up my panel.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
