Old 04-19-2008, 08:40 PM
hromani hromani is offline
Default falcon gauge update
I purchased a Glastar which has a Falcongauge
DG installed which gave up its ghost after only
75 hours, naturally it was, according to falcongauge
out of warranty and they ask me to send it at my cost
to there factory, I explained to them that the GD worked in the
upright Position but no horizontal, the only answer I got was
send it in we charge you $350 Bucks, not including fright and taxes
and duty from Canada so I decided to fix it myself, when I opened the
unit I found the glue holding the compass rose to the disk
substandard separating both disk and compass
if you have the same problem with the Chinese made
Falcongauge equipment fix it yourself. I think this
is how they make there money
If you need picture of the repair let me know and i will send them to you
Cheers
