Old 04-16-2008, 06:57 AM
prkaye prkaye is offline
Default must i choose engine now?
I'm about to oder my finish kit. The form says that if you are buying an engine from anyone other than Vans, you have to supply the engine identification form. Does this mean I really have to commit to an engine supplier now?? Or could I just go ahead and order as-if I were going to get the engine through Vans, and still be OK if I end up getting it from Superior or Aerosport later? I know i definately want an O-320 fixed pitch, but haven't decided on all the details yet.
That being said, can anyone tell me how to read the model numbers? Superior sells an
IO-320-A1AC2
I know this is a fuel injected O320, but does the rest of the code tell me the other things vans wants to know (induction, cylinder type, mount style) ?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-16-2008, 07:17 AM
Fearless's Avatar
Fearless Fearless is offline
Default They need to know what to put in the kit.
Phil,
Van's will need to know what to put in the kit. The engine type will determine what engine mount, cowl and spinner to include. I already have my engine but I am leaning toward a Catto fixed pitch prop so I would need to get the spinner for a wood prop. I'll probably order my finishing kit either late fall or early winter to try to beat next years price increase.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 04-16-2008, 07:27 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Hi Phil - I'm getting near the same spot as you. There is a Lycoming document that helps a bit reading the codes (I think it is under Firewall Forward, PM me if you can't find it). It is OK at a high level, but doesn't have a lot of details (like if the engine has a big front bearing, etc.)
I'm starting to look for an O-320, fixed pitch as well. I'm looking at all options (rebuild myself, buy used & running, new, etc.) Lots of $$$ any way you go
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 04-16-2008, 07:33 AM
videobobk's Avatar
videobobk videobobk is offline
You may well end up money ahead by deciding on an engine now. It isn't impossible to change your mind later, but you may have to exchange some parts. That may be a bit more trouble for you since you are in Canada; I don't know. Customs and all that. Chances are that you can decide on the engine type and select the supplier later without problems, IMHO anyway. By now you should have a pretty good idea of what you want (and if you are like many of us, what you can afford!)
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 04-16-2008, 08:05 AM
Default superior
I've been leaning towards the build school offered by Superior, for the educational value. I just had a nice chat with a guy on the phone there, which definately encouraged me more in that direction.
Phil
RV9A (SB)
Ottawa, Canada
C-GRVT C-GRVT is offline
You don't need to have chosen an engine supplier before ordering the finish kit - Van's needs to know what you want so it can supply the correct cowling and spinner with the finish kit - you may wish to speak to them, but I think what they need to know is: 0-320/0-360 (or whatever is appropriate for an RV-9); parallel valve/angle valve; vertical induction/horizontal induction.
Constatn speed/fixed pitch versions of the same engine use the same cowl, I believe.
If you haven't decided between carb and fuel injection, you can specify carb, which will give you the cowl with a scoop, and still decide later to go with vertical induction fuel injection.
Van's will let you know what will work with what cowl, so I'd call them and go from there.
Bill
RV-6A
Ottawa, Canada
Old 04-16-2008, 08:07 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Hint hint on spinner
Mike, get the spinner from Catto with blade portion cut and holes drilled to backing plate.
Old 04-16-2008, 08:21 AM
flion's Avatar
flion flion is offline
Superior has the info you are looking for buried on their website. You need to surf to the Build An Engine page under the XP series section. On that page, there is a link to their configuration applet but there are also three document links. The third one explains the model scheme. In the example you gave, IO-320-A1AC2, is a fuel injected 320ci parallel valve head engine with a thin-wall, fixed-pitch crank and dynafocal 1 mounts. The second-to-last digit indicates a Unison ignition/Airflow Performance injection package and the next-to-last digit indicates updraft induction and roller lifters. The last digit indicates an 8.5:1 compression ratio/160hp engine.
Van's mainly needs to know the type of engine so they can get the engine mount/cowling combo correct. If you change your mind later, you may need to return the cowling, which would be expensive and time-consuming, so it would actually be a good idea to make your decision now. Besides, if you are on the finish kit, it will not be long before you make your actual engine purchase anyway.
Old 04-16-2008, 08:46 AM
Spinner... yes I am planning to go with the Catto 3-blade. Does this mean that I should delete the spinner from vans finish kit?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-17-2008, 06:19 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Nope. I think you send your spinner to Craig and he cuts it for you. However, I cut my own and it wasn't a big deal. A couple of hours with a Dremel tool and sanding disk and you're done.
Cheers
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
