Old 04-15-2008, 06:25 PM
thinkn9a thinkn9a is offline
Default Uncle!! I give up,... which Molex tool???
trying to figure out, for the pin connectors to Whelen strobe/position wiring, what is the correct crimping tool,...
surfing around the web I either get far too much info,.. or nothing,....
So far I've seen a $724 tool and a $19 tool,... and only about 200 in between,... and no simple cross check to figure correct application
Got to believe someone here can help me.
Thanks in advance
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 04-15-2008, 06:34 PM
647jc's Avatar
647jc 647jc is offline
Try http://www.steinair.com/tools.htm tool SAT-018 MOLEX / Open Barreled Pin Crimper for $31.00.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 04-15-2008, 08:52 PM
Ted RV8 Ted RV8 is offline
Default Whelen doesn't use Molex connectors
As I recall the connectors on the Whelen products are not Molex. I believe they are Amp.
They are just a little different in sizing compared to the Molex ones.
I had an access to an Amp crimper so was lucky.
Ted
Old 04-16-2008, 07:30 AM
647jc's Avatar
That's correct, the Whelan connector pins are slightly differen't size than Molex but using a Molex crimper worked fine for me.
Joe Condon
Ankeny, Iowa
Old 04-16-2008, 07:51 AM
orchidman orchidman is offline
And while you are there, you might want to add the SAT-004. If you are doing the MOLEX/Open Barrel crimping you will probably be doing some D-Sub crimping. I got both with my initial kit from Stein and not regret it a bit. Also consider the SAT-001 with dies for the COAX connetors and the pin removal tools.
With the pricing of freight any more I am combining everything I can in each order.
Old 04-16-2008, 06:12 PM
Talking thanks everyone ! I'm on it!
well,.. it gets better,..
Van's Parts Web site,........ Molex
Van's shipping list with lights....... AMP
Connector on lights...... nothing (ok 2 digits)
One thing I do know about electrics,... crimps are NOT as simple as I would like to think,...
and the other is,.. I don't know about electrics,...
amyway,.. I'm good,.. tools on order,.. parts on order, Marietta on standby to hold for crimp
Thanks again for all the help!
9A -QB
N211LV
