Old 04-14-2008, 05:29 PM
Kevin McGreevy Kevin McGreevy is offline
Default Mystery problem with Alodine
Hi all,
This is my first post, and my mentor in MT said that I should contact y'all for this question- so he is to blame! I am not even building an RV even tho I really like the aircraft and am totally inspired by all that have taken on a project. I fly (train) in one of those glass diamonds- but I digress.
I am repairing my sailboat (home) that was damaged in Katrina and just got around to refinishing the mast. Stripped it down, sanded washed, prepsol, then a nice wash of Dupont 225s, wash and dry, conversion coat with 226s. Waited for the magic to happen. When I rinsed the 226s after about 5 min, there was no gold coloration to the aluminum. If you looked carefully, you could see a slight "rainbow effect" . The aluminum is T6061 and I do not know if that has any bearing on the problem.
So, in light of the "no-gold", went into a hold on applying the Corlar epoxy primer. Can any shed light on where I may have screwed up the process. I'm pretty anal about following directions, and I had a nice sheeting on the 225 rinse so I am just stymed.
I know you folks have treated more aluminum parts than I ever will, so I really respect your collective wisdoms. Thanks to all
All the best,
Kevin
Old 04-14-2008, 06:34 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Kevin-------welcome aboard-----yep, pun intended.
Hopefully the moderators----and I am one---will let this post stay------even though we are supposed to remove non RV stuff, I really dont see this as a problem.
Besides, Alodine is aircraft related.
Anyway, in my experience, the Alodine is pretty consistent in causing a color change.
But, we are working on alclad material for the most part, and I really doubt that there is any 6061 in our planes.
Hopefully you will get a successful answer.
And after you are through with the training in the diamond, go find a ride in an RV-------but be warned, it could cost you lots of $$$$-----the grin is not without consequence.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-14-2008, 06:58 PM
TSwezey TSwezey is offline
The only times I have seen alodine not change the color was when the alodine had been exposed to air for a long time or it been contaminated with something. Every single piece of Al on my plane has been alodined.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 04-14-2008, 07:01 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Alodine loses it's strength after a while. The yellow dye is an indicator that it is still effective. No color change on the metal surface means that it is past its sell by date. There is a "clear" variant without a dye for cosmetic applications - don't know how you know whether it works or not.
Jim Sharkey
Old 04-14-2008, 08:16 PM
Default alodine
Isn't alodine photo (light) sensitive as well? I keep mine in an old photo negative developing cylinder. Too much light...the product becomes ineffective?
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 04-14-2008, 10:56 PM
chaskuss chaskuss is offline
Originally Posted by Kevin McGreevy View Post
Hi all,
All the best,
Kevin
Kevin
Glad you mentioned that you are using 6061. It takes 3 times as long for Alodine to "convert" 6061 compared to 2024-T3 Lorne's comment about Alodine, Iridite (and others) being photo sensitive (affected by the sun) is true. However, that is more of a problem for those of us who set up dipping tanks (bathing the parts in the Alodine) while out in the sun. The first day everything works great. It's the NEXT time you try to use the Alodine that it won't work (due to sun exposure).
Either try to leave the 226 (aka Alodine) on 3 times longer OR make the Alodine stronger, which is only possible if you started with powdered Alodine, as opposed to liquid Alodine (or in your case 226) I should also mention here that powdered Alodine costs about 10% of the price of the liquid. I suspect that with shipping prices going up due to fuel costs, that price differential will increase.
Another tip is to NOT let the part dry after rinsing off the 225 (aka AlumiPrep cleaner) The part will actually start to oxidize while it dries. This prevents the conversion from taking place. Once the item oxidizes, you have to start from scratch. This is one time where the instructions give you a bum steer. Rinse off the 225 and apply the 226 while the part is still wet with rinse water.
Click on my user name to get my email address. You can contact me off list for more info.
Charlie Kuss
Old 04-15-2008, 11:27 AM
Default Thanks to all
Well, everyone thanks for the insight on this issue. Mike, my wife was standing over my shoulder reading your post and all she said was, "Oh, no. Another place to hemmorage money." Yes, I would like to build one someday, and I will definitely get a ride- but I take your warning to heart!
All the best,
Kevin
Old 04-15-2008, 02:59 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Not quite....
Mike.... most of the non-sheet stuff on our RVs is 6061-T6. All of the angles and bars, and some tubing.... and even the instrument panel (at least in the -6)
http://www.vansaircraft.com/cgi-bin/...&product=angle
http://www.vansaircraft.com/cgi-bin/...product=altube
..and I've been alodining it....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-15-2008, 04:07 PM
DrHolling DrHolling is offline
I have found that if you treat 6061 parts after a while the Alodine will impart a 'blue' colored finish instead of the normal gold. I assume it is from copper contamination from the 6061. I now have 2 seperate bottles of Alodine; one for 2024 and the other for 6061. Normally I try to 'dip' most pieces and pour the Alodine back into it's container between batches.
This is the first I've heard about the photo sensitivity of Alodine. Mine came in translucent white (almost clear) plastic bottles. I would have expected it to be packaged in a darker container. Live and learn.
Dave
Old 04-15-2008, 04:38 PM
Mike S's Avatar
Senior Curmudgeon
gil A
Gil, thanks for the education, I stand corrected
Mike Starkey
VAF 909
Rv-10, N210LM.
