There was a bad batch made in 2006 and Van's offered to replace them. I found out about it in the RVator, 5th edition, 2006 and had the cables that failed the recommended 40 lb pull test replaced. There may be a relevant service bulletin (SB) on the Van's webpage. Hopefully there haven't been more bad batches since.
It's good practice to pull test all connections, home made or otherwise. After all Van's isn't an FAA certified fabricator and we are all responsible for our own build. (We should probably also test the rudder cables.)
Ironically after I actually started wiring I found out that I didn't need most of the cables supplied. The wiring kit covers many models and configurations and therefore has a lot of redundancy in terms of the big power cables.
Jim Sharkey
RV6 - Wiring and final bits
