04-07-2008, 07:43 PM
Brake pedal non slip tape
I've seen a few builders put some non slip grip tape on their brake pedals. Does anoyone know where I can find this?
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
04-07-2008, 08:09 PM
Hardware stores. Get the 3M brand, it will stick forever.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
04-07-2008, 08:10 PM
tape
Nonskid safety tape. Safety supply division of HD or Lowes. Possibly dedicated safety supply stores. I own a retail building supply store and we carry the 2" wide self adhesive tape by the roll. Used for providing nonslip surfaces around floor mounted power tools and stair nosings
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
04-08-2008, 07:04 AM
I used some of Van's wing-walk non-slip material. Cut a piece slightly oversized for the pedal, stick it on, and then trim with a razor blade to the contour of the pedal. I also used this method to trim the pedal lightning holes.
04-08-2008, 07:20 AM
Local sports shop
My local sports shop has rolls of wide anti-slip material, just like for the wing-walk. They use it for skate board tops.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
04-08-2008, 07:53 AM
Another option
I used pickup truck bed liner (Herculiner)for my pedals and floor. It is a single part polyurethane with ground up rubber granules. Easy to apply and clean up. Looks great after 2 years and 275 hrs.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
04-08-2008, 06:43 PM
Well I drove over to Wicks Aircraft today and bought some clear wing walk tape. I just put it on and I have to say it looks pretty bad. The clear just does not look right on my black powder coated brakes. Is this stuff really necessary? If it is then I think im going to peel it off and try again with the black kind.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
04-08-2008, 08:34 PM
VAF Moderator / Line Boy
Well, I personally like to be able to slide my feet up and down on the rudder pedals and brakes, which means I don't really want non-skid on them - so I guess for me it's not necessary. Lots of people like it though, so I guess you might think about how you generally operate rudders and brakes and then decide what is best for you.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
04-08-2008, 08:37 PM
Thanks, thats all the motivation I need to peel them off.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
