Old 04-05-2008, 07:04 PM
RVWanabe RVWanabe is offline
Default Experimental plane & pilot requirements
Hello group.
Today, I went to get my BFR to a different place than I normally go. They held a ground school for four of us. There were a lot of things discussed. Many of them I did not know. The ground school did not cover experimentals. If the experimental requirements are any thing close to general aviation you will be surprised. I put these questions to the group. These questions relate to experimentals not general aviation.
I bet manyt of us don?t have all the stuff needed for the plane or the pilot.
QUESTIONS (for experimentals only)
1. Do you know what things the PLANE has to have to be legal for flight? Day & night. For ABCDEG airspace.
2. Do you know what things the PILOT has to have to be legal for flight? Day & night. For ABCDEG airspace.
Once all these questions are answered, should the site save them in a special file for all to reference?
Thanks, Ivan from Sugar Land, Texas.
Old 04-05-2008, 07:30 PM
TSwezey TSwezey is offline
Really just about everything is similiar for legal flight for pilot and plane. The experimental plane must have experimental labels.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 04-05-2008, 07:47 PM
N941WR's Avatar
N941WR N941WR is offline
BTW, Experimentals are "general aviation".
The only odd thing about Experimentals is that there are no endorsements such as high performance, complex, and/or tail wheel required, unless they are written in the aircraft?s operating limitations.
I did not know this until my FAA inspector pointed it out to me and made sure I had my TW endorsement.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-05-2008, 08:00 PM
John Clark's Avatar
John Clark John Clark is offline
Default "Stuff?"
I'm with Todd on this, it is rather simple. Assuming that the experimental aircraft has finished Phase 1 and has the proper equipment and wording in the Opps Specs, you are good to go. For the pilot, same story, properly rated for what you want to do. Things like an instrument rating to fly in Class A or a sign-off to fly in Class B on a Student Pilot License are no different in an experimental or certified aircraft.
So what did they teach you that was so surprising??
John Clark ATP, CFI
FAAST Team Representative
RV8 N18U "Sunshine"
KSBA
Old 04-05-2008, 10:05 PM
airguy's Avatar
airguy airguy is offline
Question for Mel (or another FAA-knowledgeable person) - do we as experimental flyers need a high-altitude signoff before flight about any given flight level?
Old 04-05-2008, 10:20 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default O.K., I'll take a guess.
Q1. ARROW, for the paperwork, IIRC. Oil pressure gauge, fuel gauge, compass, airspeed and (?) altimeter.
Q2. Pilot Cert, medical, current BFR.
Above are for day VFR minimums.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-05-2008, 11:04 PM
John Clark's Avatar
Default High Altitudes
A High Altitude Endorsement is required over FL250 (25000 feet.) Interestingly the regulation says "pressurized aircraft" but if you are planning on anything in the flight levels I would strongly recommend the training. Bruce Bohannan not withstanding, I really don't think you want to be anywhere near FL250 in an RV!
Here is an Advisory Circular on the subject:
http://tinyurl.com/5vjvoz
John Clark
RV8 N18U "Sunshine"
KSBA
Old 04-06-2008, 06:10 AM
pierre smith's Avatar
Default Oplims...
......must be carried aboard experimental AB aircraft as well as airworthiness and registration certificates,
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-06-2008, 06:37 AM
Mel's Avatar
Mel Mel is offline
These requirements come from 91.205 which applies only to "Standard" certificated aircraft. 91.205 does apply to amateur-builts for night and IFR operations per your operating limitations.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-06-2008, 09:36 AM
airguy's Avatar
John Clark
RV8 N18U "Sunshine"
KSBA
That was my understanding, that it would not apply to an unpressurized aircraft. Granted, you're tickling the dragons tail in any case - just curious about the paper requirements for actually doing it.
